Terazzo step??
G
gcltd
Hi, we are about to remove a upvc door and the threshold will be replaced with a flat aluminium one, we were told this threshold cannot sit on brick and we'll need a terazzo step installed for the aluminium threshold to sit on?
Is this correct?
Would a concrete block/beam not be suffice?
Yep, so whilst your replacing the threshold bar perhaps you should replace the contractor...better still ask him why, for gods sake!...pinenot
There could be a valid reason for this, can you put a picture up of the existing door cill and threshold. Clearance could be a problem if you're replacing a pvc threshold with a 25mm Ali one, problems with drainage could also be an issue if sat on block/brick
Terrazzo is quite a specialism, My thoughts here are that someone someplace is trying it on, Having said that terrazzo would give you the finest impervious floor for a weatherproof step. As I said (sorry if this sounded aggressive to you by the way: oops:) why not ask him?...pinenot :)
