Forget it how are you going to get a unit that only can trigger 2 events (no mention of restore events ) to send 3 events - alarm / arm/ disarm ?
Perhaps I haven't been as clear as I should have been... I'm aware it can only trigger 2 different events, the priority event I want to trigger is obviously "Alarm" but as it has a 2nd input to use then having a trigger upon "Arm OR Disarm" is a bonus. I know the triggered 2nd input wouldn't state which event occurred but I could live with that.
Okay this is all besides the point as your gsm cant do what you want anyway.
gsm com module would be a better option and you would get more information out.
The problem is the custom output wont allow an inverted output pulse, thought I had done something like this years ago, but the closest I can find is inverting the output and assigning to a physical to make it make it pulse.
When looking at wiomtex diagnostic screen you can see whats going on, but whilts it do armed pulse, wont do the invereted armed pulse so cant combine. tried to do the custom into a custom no armed and still no joy.
At this point the only way is two physical outputs to be combined as 1 either one firing them off (relay).
at least its given my brain some exercise, even if it was pointless.
Well, my gsm thingy CAN actually do what I want (see above reply to sparkymarka) so definitely not a pointless exercise! Thanks for the explanation of why the pulse doesn't work, pity as it looked good in theory.
Best bet buy a cheap comm 2400 off ebay for around £10 if you have a landline and use the comm2400 to give open/close reports or Nokia 6310i dlr3p nokia serial lead and a Unicom lead = gsm unit.
No landline to use, and I really don't want to start purchasing additional components. Now I know the issues, I'll make do with the trigger on Entry/Exit, I'm sure it'll be fine.
Appreciate both of your inputs (excuse the pun) here, it was interesting to see what the hardware can - and cannot - do!
