The right sander
18 Oct 2009
Hampshire
Hi
I'm just about to embark on the daunting task of decorating our hallway, stair and landing.
Although the house is reasonably new circa 2011 the wall need a filling and quite a lot of sanding to get them smooth and the frames seem to have been drenched in paint so with 9 door frames to sand its not an overnight job.
Now my mouse sander has just packed in so I am looking to replace it with something a little better that might be able to do the walls as well. I have a Bosch multi-tool which I've purchased a triangular accessory for sanding which should do the smaller tighter jobs but what type of sander do I need for the rest?
We also have the stair spindles and banister to do but I'm assuming that's a hand job!
Any help appreciated
I have an orbital Titan from screwfix at about £50 which I am happy with. Details are great but bugger doing a wall
I have used a Bosch orbital sander PEX12AE for many years and it's been brilliant. Last year, after 19 years use I had to replace the grip pad (not dear, and easy to do) but that only reflects the amount of use it's had!
You need a dry wall sander and vacuum for walls.
But something like Abranet mesh pads and hand sanding can be just as quick, easy, and less mess.
