This is my first post so please be gentle.
Setup:
Worcester Bosch Greenstar 24i System boiler
Danfoss RET B-RF wireless thermostat (RX-1 receiver with Danfoss RET-B wireless thermostat)
Danfoss FP715 Si Time clock
All new and installed earlier this year by a reputable company that holds all the required certifications etc.
Something a little odd has been happening and I am not entirely sure if this is normal or the sign of a problem. The system appears to be operating 100% correctly most of the time and I am getting hot radiators and water with no issues.
My concern is that I am getting what I think it odd behaviour once the house is up to temperature. Sometimes, I am finding that the boiler will go off and stay off for say half an hour during which time the house temperature obviously drops. The thermostat seems to then call for heat when the temperature drops to the setpoint but, the thermostat only seems to call for heat for a minute or two and then stops. This repeats over and over so that I am getting several very short runs from the boiler. It's as if the themostat is reading a temperature drop and then almost immediately seeing the temperature going back above the setpoint. This sometimes happens three or four times in the space of 20 minutes and I am guessing that all the firing up for short times isn't going to do the boiler any favours.
I thought it might be due to something simple like a draft so, I moved the thermostat to another room and get the same results. Any opinions as to whether this is a problem or normal operation? Seems a little odd to me and I would have thought that the thermostat would have some internal deadbanding or debouncing built into it?
Thanks in advance!
Setup:
Thanks in advance!
