Thorn Olympic 38 50b boiler problem
31 Oct 2010
Devon
Hi all
Issue with this boiler, basically the pilot light is on but the boiler stopped firing up last night. It is a very simple installation, just got two switches on the wall, one for hot water and both on for hot water and heating. The pump comes on but just doesn't fire up.
Got a plumber coming in tomorrow but wanted a heads up on what it might be in advance. I don't want him going down the new boiler route if this one is fixable.
Many thanks!
Simon
Not possible to guess from here, I'm afraid. It might be something quite simple and cheap, or simple but expensive, or simple but obsolete..
If the timer is the integral one on the lower right of the boiler, it could be that - they drop to bits.
Get the engineer in may be the internal timer, it can be replaced with a wall mounted one, it may be the boiler thermostat, again should be repairable or possibly the gas control could be at fault Honeywell V4600C is quite cheap to replace so unless there is something more sinister like a corroded flue duct or internal leakage your old cronk should be fixable P.S. I binned the Olympic 30/50 in my house about 15 years ago!! ;)
