i have had my bathroom replastered and down one corner which has cracked line about half a metre long, only a few mm thick, as i am having the walls tiled shortly do i need to worry about this ?. or will the tile adhesive sort this out?
hello, as long as the tiler bonds the walls before they start tiling and if you wont to be 100% with it scrim tape & apply it will pva. you will be okTap the plaster with your knuckle - if it sounds hollow it needs replacing. If not, it'll be fine.
