Toilet leaking by the outlet pipe
7 Aug 2007
Bedfordshire
Hi :) , can anyone help me and tell me what type of sealant i need to use as the 2 pipes on the back of my toilet which are connected togeather have lost some of the sealent from it and when i pull the chain the water comes out of it :(
I have uploaded the picture for you.
I would clean and dry the joint and then squirt a nice thick (but tidy) bead of Sanitry sealant into the gap and wipe it into the joints.
Leave ofr an hour and test.
Make sure the loo is FIRMLY screwed to the floor as movement will bring the leak back.
A bit of practice and you would be amazed at how neat and tidy a bit of white silicone can be. If you change it (indeed with an offset connector) you'll need to remove the loo and allsorts.
Thxs for helping me u guys and i will be following your advice , very grateful indeed and a big THANKYOU :D
UPDATE- Silocone worked a treat, very happy and can now flush my toilet with a smile on me face :D , thankyou for helping me out !
