toilet water inlet
18 Feb 2006
Birmingham
while im tiling i wanted to temporaily connect the WC.
As it will be tiled behind i dont want to fix it first to the wall and hence dont know where the water inlet needs to be.
Can i use plastic pipe to connect from a compression joint to the inlet of the cistern? if so what else do i require?
thanks
flexible tap connector
