triton shower
5 Mar 2005
had triton engineer out cos my new shower wasnt working properley .he said the pressure is not good enough,its working ok now but i want to know whats the worst thing that can happen .ie will it keep cutting out or just run slower
The low pressure safety cutout will cut in, ready for a cold shower half way through?
Think they need about 1.25Bar working pressure.
Tee in a pressure gauge to the shower feed pipe - see what the pressure drops to when using the shower.
Read the installation guides they will tell you the minimum working pressures at a particular flowrate.
Alternatively if you can fit a suitable cold tank, electric showers are available with a pump built in.
The higher the Kw rating the greater the working pressure needed as a general rule.
1.25 WP should just about be enough for a 9-10 Kw hopefully.
