When I fitted my TRVs I used the new olives that came with the TRV packs. If you're taking off the old ones becareful, they can be held on to the existing pipe quite tightly, so careful not to bend or mis-shape the ends of the pipes.
If the old olives wont come off, use PTFE tape or there's something call Boss White.
I'm sure a professional will be along to help in a mo...
Any half-inch BSP nut will usually fit the valve inlet. Trick is to be relaxed about it! If the reason you want to use the old nut + olive is water running out of the pipe -you got it wrong!
Give yourself time (by draining-off properly, etc.) to be able to take a good look at the state of the pipe, nut and olive. Pipe reasonably clean and round? Olive NOT been over-tightened already (it should look more-or-less like a new one)? Nut in good condition, so it won't look ****e for ever after? Enough pipe sticking out the olive to properly engage with the valve body? Pipe actually right length and in the right position?
If yes to all these, there's no reason to take the olive and nut off.
