Turf cutter problem
6 Jun 2015
Leicestershire
Hi
I've hired a turf cutter to take up a small lawn at the front of my house but I just can't get it to cut the turf. Can anyone help?
The cutter is one of the small yellow light duty ones.
I've tried having the cutting blade at different heights but when ever the blade comes into contact with the earth it stops moving. I've felt the blade and it's not razor sharp. To me it seems as though either the blade is not sharp enough or there's something up with the machine as it doesn't seem to have the the power to keep the blade going once it hits the ground .
I've cut the grass nice and short and I watered it a few hours prior to starting the job.
Does anyone have any advice or thoughts ?
Tom
Thanks for your reply but when I follow your link the second video down is a video from hss about a turf cutter but nothing about blade problems. I've searched and can't find anything similar. Can you tell me who the video is posted by?
I thought the HSS one might be the same as the yellow one you hired, obviously not. Can you see the blade moving back and forward as it cuts the sod out?
Or give the hire company a wee ring tomorrow .........
Ah, yes.. Similar model to what I have. Blade moves same as in hss video but as soon as hits ground it stops. I'll try hire firm tomorrow. I now know why they call it sod!
In what manner does it stop? does it die through lack of power? You should be able to turn up the revs via a throttle on the bars?
