UPVC Door Sill
10 Aug 2009
Yorkshire
Evening Gents,
I'm looking at buying a 2nd hand UPVC door. However i have a problem, the door including sill is 2095mm high and my opening is 2085mm high.
Is there anyway in which i could get in to fit?
Many Thanks SB
Cut the ribs off the top of the frame and if still not enough cut the back 2 and the 3rd off the bottom, leave the 4th (the outer one) on as that doesn't affect the height and it'll give you a clean straight finish when you look at it head on
