Urgent Help Required - Mains Drains layout on new build
Discussion in 'Building' started by anuraj, 5 Apr 2012.
  1. anuraj
    11 Jan 2012
    4
    Thanks Received:
    London
    Country:
    Hi All,
    I urgently need some advice on main drains layout.
    My property was an old bungalow without main drains.
    Now we are looking to start a new self-build I want to ensure I am on the right page with the layout of the new waste system.
    Below is a image of the layout I am thinking of.
    The main connection is at the foot of the driveway and is 1400mm below the ground level.
    Please can someone advise if I am on the right page with this design or if it can be improved...
    Help Much appreciated!
    EDIT
    The dotted line points in the direction of my outbuildings - I may want a connection from them one day...
  2. freddiemercurystwin
    21 Jan 2007
    16,718
    Thanks Received:
    1,807
    Devon
    Country:
    Why not get rid of IC-B & C and run all 3 soil pipes into IC-A, maybe moving it the left a little?
  3. garyo
    11 Apr 2006
    1,011
    Thanks Received:
    70
    Berkshire
    Country:
    Why the urgency?
  4. anuraj
    11 Jan 2012
    4
    Thanks Received:
    London
    Country:
    I have reworked the drawing as per your recommendation and here is what I got.
    I have two main worries:
    - The lengths of the main run
    - is the main run @110mm sufficient to cope with the flow?
    max setup for the house will be:
    - 8 toilets
    - 10 basins
    - kitchen outlet
    - washing machine
    With this setup, the new drainage will need to cross under the footings at 3 points.
    Any thoughts?
  5. anuraj
    11 Jan 2012
    4
    Thanks Received:
    London
    Country:
    I want to start the footings, next week. The whole ground floor is suspended block and beam, raised 1m off the ground.
    My groundworks guys have let me down, so I have to solve this before the rest of the schedule starts to back up.
    looking to get all the pipes under the building in whilst I can use the digger onsite and before the block and beam floor - will connect up and commission the system later.
  6. freddiemercurystwin
    21 Jan 2007
    16,718
    Thanks Received:
    1,807
    Devon
    Country:
    I was suggesting you ran all 3 pipes into 1 chamber rather than have 2 of them join the single run under the house.
    Why so many toilets and basins?
  7. ^woody^
    3 Sep 2006
    17,839
    Thanks Received:
    1,968
    West Mids
    Country:
    I would suspect that inaccessible connections beneath a building would not be acceptable
  8. mikric
    6 May 2007
    685
    Thanks Received:
    32
    Lincolnshire
    Country:
    Get rid of the connections under the floor ;)
    why would you want to take an external SVP back in under the floor :confused:
    A 12m run is the max between ICs, get the drains outside of the building as soon as possible.
    • Thanks Thanks x 1
  9. fmck
    27 Dec 2010
    254
    Thanks Received:
    19
    Ayrshire
    Country:
    If you can acheive no connections under your floor you will most likely be the first building to do this and would recommend you patent your idea :D
    If time is the main issue just make sure all your pop ups are in and clearing the building. MOST IMPORTANT IT PASSES A PRESSURE TEST
    You need that test to pass after any incasing in concrete.
    Witness it yourself but BC will eventually want to see it pass.
    Get your builder to release one of the bungs at the far end of the line while you witness the guage drop to ensure he hasnt cheated once the test has held to satisfaction.
    Everyone will cheat if its not holding its easy to do and save a lot of hard work to put everything right.
    At the end of the day if your pop ups are clear of the building it easy enough to direct them from there.
  10. Norcon
    17 May 2008
    8,419
    Thanks Received:
    357
    Country:
    Where do you get that from? I know hundreds of buildings with no drain connections under the floor. Hardly something new. :rolleyes:
  11. theoldun
    18 Apr 2010
    1,244
    Thanks Received:
    325
    Bedfordshire
    Country:
    With respect both your drawings are a waste of space. It is an easy house to drain. Answer a few questions and will tell you how.
    Is it going to be bungalow or house?
    Is it block and beam floor?
    My eyes are not so young now, so IC- B, does that read invert level is 775mm below ground level?
    IC- A, does that read invert level is 1050 below ground level?
    IC- B does that read 675mm below ground level?
    Why is the bottom soil stack external?
    What is datum of dpc in relation to IC- B ground level?
    In answer to your other questions, we take up to 10 units on a 110mm pipe, each unit consisting of WC, bath, wash basin, sink and washing machine running at a flow rate of 4.1 litres second all as H1 table 5 BRs. We change our flow rates around on our falls though to avoid a bottle neck at the discharge point into main sewer.
    Regards oldun
    We have always been under the impression that between IC and IC it is 22m
    Regards oldun ;)
  12. fmck
    27 Dec 2010
    254
    Thanks Received:
    19
    Ayrshire
    Country:
    Point was if your pipes are below floor you have to have a connection unless there is some new fangled flex 4" that does it.
    No one these days wants plumbing coming out of exposed walls outside didnt even consider that one on a new build. Would you?
  13. mikric
    6 May 2007
    685
    Thanks Received:
    32
    Lincolnshire
    Country:
    [quote="theoldun"
    Regards oldun ;)[/quote]
    Have you ever seen anyone trying to use 20m of drain rods :LOL:In my opinion I would say that 12m is more practical, the regs have not been updated for years and there is loads of stuff that drains are "expected" to deal with nowadays, wetwipes, sanitary towels etc.
    If I were doing a new build for myself no way would I go for 22m but if you are happy to go 22m between ICs then go for it :cool:
  14. Hugh Jaleak
    3 Feb 2008
    4,763
    Thanks Received:
    901
    Northamptonshire
    Country:
    Try rodding a 91m run with 'Steel Kane' rods..... (Some muppet had built a conservatory over their manhole, then claimed they didnt have one.... Only house in the street that didnt then?)
    22m isn't a massive run, and with the jetting gear most contractors carry these days, shouldnt be too difficult to deal with.
  15. anuraj
    11 Jan 2012
    4
    Thanks Received:
    London
    Country:
    Many thanks to everyone for the responses.
    My apologies for the late reply - I have been away for easter.
    Here goes, answering the questions:
    This is to be a house. The image shows the new proposed footprint.
    The floor is block and beam. The DPC level is 1m off the ground, meaning the void under the block and beam floor is around 800mm.
    This is a flood regulation in our area.
    My apologies as the terms I used are maybe not 100% accurate.
    The levels are indeed the depth from the ground level to the bottom of the trench - following a fall of 1:40
    IC-A - 1050mm below ground level
    IC-B - 775mm below ground level
    IC-C - 675mm below ground level
    I have no idea if this is the correct layout or if so many IC's are even needed.
    The starting point is, the main drains connection at the foot of the drive way is 1400mm below ground level
    They stack is external as I don't want it running up in the front living room + thought it would give an external access point if needed.
    The DPC is 1000mm above the ground level of IC-B.
    Any design / help with layout from anyone would be much appreciated!!
Loading...
Share This Page
