The cold has caused 2 of my neighbour's garden taps to start leaking dramatically ...both were insulated - mine isn't.......
Made me look to see if I had an isolating valve on mine - only to discover I don't.
(One of my neighbours discovered their kitchen fitters re-plumbed so that the garden tap bypasses the stopcock ... they have had to call out the emergency plumber...)
My tap outside and piping is copper/brass but the run to it inside is plastic with a couple of pushfit elbow joints....there is a stretch I could fit an isolator on but I've no experience of this stuff...
How do I disconnect the joints? Can I reuse them?
Do I really need to pay £15/16 for a special pipe cutter? And if I get one of these would I be able to cut a section of the pipe out where it is and not have to disturb the joints? Using a pushfit 'service valve'.
Or I probably have a length of 15mm copper that I could replace the
plastic with ...thinking put a standard compression isolator on it and connect up to the elbows...
Any tips /advice gratefully received...looking to tackle this job asap...
(no point insulating the tap just now - it must already be frozen)
