Vaillant Boiler F.28 Ignition Failure
Discussion in 'Plumbing and Central Heating' started by Bennet, 27 Nov 2013.
  1. Bennet
    27 Nov 2013
    3
    Thanks Received:
    Country:
    Hi there,
    We have a Vaillant boiler "ecotec plus 837".
    Yesterday night it wasn't on. The fault code read "F.28 - ignition failure".
    The manual said to restart the boiler.
    I did this. The first time the fault came up again very soon.
    The second time the fault was gone and we had heat all evening.
    This morning the fault is back - F.28 but this time in combination with "F.54" - which the manual tells me is a fault with the gas supply.
    I reset the boiler again, and came back to check after 5 minutes.
    The fault code had now gone back to just F.28.
    I reset it again and now we have heat.
    The gas cooker hobs are and have been working fine, and we've had no work done on the pipes, so gas supply seems unlikely to be the issue. Water pressure is fine.
    Some time during last week we had a power cut. The boiler has been working fine for 4 or 5 days since though.
    I know from the manual F.28 can be a number of things.
    If it comes back, is there anything I should try before giving up and calling an engineer?
    Many thanks.
  2. Agile
    26 Jun 2004
    61,372
    Thanks Received:
    4,286
    London
    Country:
    We don't advise or give any assistance with gas or combustion related issues here.
    I am a little surprised that you are getting that fault code. How often have you had the boiler serviced and how long ago was the last time?
    Tony
  3. The831Bunny
    18 Mar 2008
    1,275
    Thanks Received:
    689
    Country:
    F.54 indicates its a new generation ecoTEC (introduced June 2012). It will still be under warranty if the first year service has been carried out. I'd get back to the engineer that did that service or Vaillant for a warranty call.
  4. Bennet
    27 Nov 2013
    3
    Thanks Received:
    Country:
    It's not even a year old, so never yet been serviced. It will be a year old in January.
  5. Bennet
    27 Nov 2013
    3
    Thanks Received:
    Country:
    Will do then. Thanks.
Loading...
Share This Page
