There was a problem with 937 that has now been resolved.
If you want a wall hung fast flow boiler it has no real competitors.
I chose my words carefully.
My company fit them.
You go to exhibitions, read brochures, look on the internet.
The Worcester 42Cdi gives an inferior flow rate (the Worcester highflow 440 is the competitor to Vaillant's 937),
the Alpha is an Italian boiler with nowhere near the build quality of the Vaillant,
and the Ethos is a niche product which has not proved itself in the UK market and needs external accessories, making your space saving claim disingenious.
It is easy to make a combi smaller if you leave significant parts out of the case. Also the Mikrofill ethos does not appear to have any plume management equipment available, which is a major drawback in the mainly horizontal flued UK market.
I've received a lot of good advice on this forum, no question. Always learning, always researching.
Tell me how many Ethos units you have installed and I might be inclined to sit up and listen.
You wax lyrical about all sorts of equipment but clearly have no practical experience. For instance, I could write all about the pros and cons of an ACV Heatmaster which you regularly recommend. Some of the parts you need aren't in the manuals or the web site. But if you hadn't fitted one you wouldn't know.
Finally, the Vaillant 937 delivers 200 litres in the first ten minutes at 35 deg delta T. Are you telling me the Worcester 42CDi improves on that?
I think the Worcester 550Cdi is going to be good and is based on a proven lineage and the WB5 Heatcell. We are already taking orders for it.
