Vaillant or Broag Remeha?
1 Nov 2010
Hampshire
Given the choice between a ecoTEC plus 618 or an Avanta 18s is one much better than the other?
Everything I read says that the Vaillant customer support is awful although the boilers are good. The Remeha approach seems more helpful with a lot of information on their website. The Remeha controls look like they might be better than the Vaillant's. How do the Remeha boilers compare?
Toss a coin, I suspect you'll get pretty much a 50/50 split on this one. I'd run with the Vaillant, but only because that's what we currently use, I have no experience of the Avanta range
As I understand it ? & I might be wrong ? but Broag Remeha use sub contract labour for any in warranty work ? were as Vaillant have there own directly employed engineers !
There is NOTHING wrong with properly appointed Service Agents we are proud to be associated a several boiler manufacturers and aim to provide them with the same service they would get using their own guys!!
However the group that owns Remeha (De Dietrich) have jut taken over Potty/Baxi so i suspect the Heatteam will be looking after The Avanta range in the future
To answer the OP's question the Remeha is a far superior boiler to the Vaillant ;)
The more discerning installer would install a Veissmann over these every time.
Better engineered, and a full 5year parts and labour guaranty!
Yes, but only if money is no object.
The Broag will be approx £200 less than the (inferior IMHO) Vaillant. The Viessman will be a few hundred more than the Vaillant.
My parents 5 year old Vaillant has had three repairs, and is noisy. My Broag Avanta has proved totally reliable, and is so quiet I can hardly hear it running.
Check your figures! Viessmann are slightly dearer than the Remaha but less than Vaillant,
£150-£200 is nothing when you consider the warranty, reliability and lifetime of the product.
It cost £100 to fill a Ford Transit up with fuel these days, think about it as you need to as it's a no brainer to pay slightly more at time of purchase!
You will be delighted once it's fitted. Think again!
Since it looks as if the boilers are considered roughly equal then the controls would be a deciding factor.
One of the things that would help make the decision is knowing which one will give me a 7 day programmable, wireless, modulating thermostat with optimisation. I'm not so bothered with weather compensation or at least I don't want to be stuck with it if it doesn't work that well.
Nothing wrong at all , providing those whom purchase the boiler are aware of it .
Under certain circumstances ? complications can arise from useing a manu that uses service agents !
Perhaps my figures were a little skewed, because I get good discounts on the Broag as I fit quite a few. I rarely buy Vaillants or Viessmans.
However, and I am willing to be corrected on this if wrong, but a mid-sized Broag combi should be available for not much more than £700. The other two wouldn't leave much change out of a grand.
Broag combis are available with Opentherm compensation.
Vaillants & Veissman combis a grand ??
Go for the Remeha OP , stainless steel heat exc same as the vaillant & veissman , doubt there is any difference in quality ?? may be , possibly ?
Viessmann 30 kw Combi £745 including vat.
The heat exchanger is superbly engineered,cohesion with. 10 year warranty.
