Vauxhall Astra 1.3 CDTi ecoFLEX 16v Exclusiv
25 Jun 2008
Yorkshire
Hello, I'm after some advice on the named car. How will I get to the fuel sender unit? Reason been the fuel gauge isn't working.
Thanks Nathan
I've had absolutely no dealings with that particular car Nathan, but access to the tank is often below the rear seat squab, maybe hidden by a metal plate or a large rubber grommet....have you checked down there?
John :)
Hi John, thanks for replying. I removed the rear seat but I couldn't see anything apart from what looks to be a plastic section, not sure if it comes off tho. I will take a picture tomorrow mate.
The fuel sender unit and fuel filter are a single sealed unit attached to the fuel tank and is quite an expensive unit and I'm sure the tank requires removal to gain access to it.
