Velux - Double or Triple Glazed
22 Nov 2007
Hi all,
We will be converting a shed adjoining our house into extra living space and to keep our privacy (and our neighbour's privacy) we are planning to fit three large (1.34 x 1.4 m) and I would like your thoughts on whether we should get the double or triple glazed pane fitted ino the Veluxes?
The windows are planned to be in the new living room (x2) and my study (x1), in a South facing roof. They will be connected to teh rooms through light-tunnels and, as such, will be the single highest point in each room so, as heat rises, I thought that triple glazed would be better. However, having discussed my plans with colleagues, they think it's overkill and I'd be better off saving the money by just getting double glazed units. The price difference is £440 for three windows.
Any thoughts? Thanks, David
No point having triple glazed if the heat will be lost out through any other part of the room, is it going to be sufficiently insulated?? The veluxes should give you a u value regarding energy efficiency
Hi DHFrames,
The remainder of the conversion will be insulated, I'm waiting on the builders getting back to me with a quote and breakdown but my thoughts are as close to 100mm insulation panels on the walls (single-skin block), vacuum insulation panels on top of the concrete floor and glass wool in between the ceiling and loft floor.
I know it's a trade-off between losing as little possible heat against keeping the largest floor area but I could save some money for extra insulation by going for double-glazed Veluxes, about £450 in total. Any further thoughts for me to consider?
Thanks, David
