Veritas 8
5 Feb 2013
West Midlands
Hi Guys, I am new here and would appreciate some advice. Just moved in, alarm code provided but alarm not demonstrated, so not sure if it really worked before. Have replaced PIR's with pet friendly ones, with 6 wires connected per previously.
The new PIRs have a 1, 2 or 3 pulse jumper on the mini PCB which can be configured. Any ideas which is the correct pulse setting for the Veritas
Bob
The pulse setting just means how many times the detector needs to detect movement before it sends a signal to the panel. Leave the detector on the factory default unless you have any problems with it.
