veritas excel lcd remote keypad
18 Nov 2014
Middlesex
I have the above alarm system installed, been working perfectly however this evening whilst setting the alarm for the night part zone 1 downstairs, the system would not set, it's showing that zone 3 is open. All the sensors seem to be working the red light on the detector comes on when I'm in detection range. Normally when setting the LCD will flash with the zones being omitted, it does show that however zone 3 is not flashing. Even when setting the full system number 3 is still showing and preventing from setting.
Please can anyone provide a solution or advise what may be the cause.
TIA
need to check your part sets
menu 51 is part set 1 so whats on / off in that menu?
zone 3 is active an you have manually omitted it when setting by omit 3 prog.
So if zone 3 is supposed to be secure and its not, put a link in zone 3 at the panel end, this should stop the zone from going active.
If it does go active with the link in theres a problem with the panel, if doesnt with the link in the problem is on the cabling between the panel and the device or the device its self.
Twisting the two alarm cables at the the detector end and testing will tell you if theres an issue on the cable or on the detector.
there are more things to do if you dont find the fault that way.
Ok, will try, can you just tell me exactly how to put a link in zone 3 at the panel end? My brother installed the alarm system but he's on holiday for 2 weeks. Thxs
Not sure you should be looking at the system at all to be honest.
a link is a wire or staple placed across the the two zone terminals.
as you can manually omit the zone and things are okay, I would do that until your brother gets back off his holidays.
Couldn't agree more.
okay, press reset twice, whats displayed?
Start to set the system whats displayed?
cancel the set by typing in your code or press reset twice
Put a link in zone 3 and repeat.
if zone 3 is active, either its a programming issue and the zones been inverted, or a dry joint on the board possibly.
Your brother back off holiday now?
