Very hot circulating pump
Discussion in 'Plumbing and Central Heating' started by yogithediyer, 8 Dec 2010.
  1. yogithediyer
    5 Dec 2010
    5
    Thanks Received:
    Bath
    Country:
    Our heating is working fine, boiler fires pump, rads get hot, but the circulating pump is very hot to the touch. Pipes either side are also very hot. Bled rads, circulating pump and valve next to hot water cyclinder but only a little air and then black water. Any ideas why its so hot?
  2. boabcelt
    27 Jun 2008
    980
    Thanks Received:
    265
    Fife
    Country:
    Your heating is on? :LOL:
  3. gordongas
    8 Sep 2005
    1,027
    Thanks Received:
    105
    south cumbria
    Country:
    the water in the system is around 75 deg so it is going to be hot
  4. yogithediyer
    5 Dec 2010
    5
    Thanks Received:
    Bath
    Country:
    yes its on
  5. yogithediyer
    5 Dec 2010
    5
    Thanks Received:
    Bath
    Country:
    Should it be too hot to touch?
  6. seco services
    3 Dec 2007
    15,656
    Thanks Received:
    1,248
    Essex
    Country:
    useally yes
  7. yogithediyer
    5 Dec 2010
    5
    Thanks Received:
    Bath
    Country:
    Thanks. I'm clearly make a deal out of nothing. Just seemed odd.
  8. Burnerman
    7 Feb 2008
    16,411
    Thanks Received:
    3,187
    Northumberland
    Country:
    If your rads are nice and cosy too, then just kneel and give thanks.....especially if you have a condensing boiler!
    John :)
  9. John506
    14 Nov 2006
    1,382
    Thanks Received:
    72
    Merseyside
    Country:
    Little concerned about the part were you said black water comes out.
    Your CH water shouldn't be black, and will not last very long if left this way.
  10. andrekhoury
    6 Dec 2010
    7
    Thanks Received:
    Country:
    since its a closed system the circulating pump should be connected to the return pipe of the boiler meaning boiler temp is 80 c goes to radiators and hot water tank then circulating pump then boiler again usually the return line is 10 or 15 degrees less then ur supply temperature due to heat exchange the pump should be hot but u can touch it , if ur circulating pup is on the return line of the boiler make sure the pump circulating speed is slow this way ur efficiency goes higher and return pipe become less hot meaning ur pump is less hot
  11. 45yearsagasman
    14 Mar 2010
    5,894
    Thanks Received:
    1,036
    Norfolk
    Country:
    What reasons do you give for all that drivel. :eek:
  12. andrekhoury
    6 Dec 2010
    7
    Thanks Received:
    Country:
    well i guess u dont want to learn how to adjust ur hot water system :p i guess i gave u lots of info usually u take this in mechanical engineering but since u did not understand anything why bother happy winter:)
  13. Blooflame
    22 Nov 2009
    189
    Thanks Received:
    29
    Warwickshire
    Country:
    BRILLIANT!!!LOL!!
Loading...
Share This Page
