Hello I was wondering if someone could give me advice on a problem I am having with my Vokera Compact boiler.
The boiler has been installed for about 8 years and all of a sudden rusty coloured water is continually running from the overflow pipe. The filling loop is ok but the boiler is filling up all the time and overflowing. The pressure gauge is always on max pressure.
I have had the boiler serviced on a yearly basis and have not had any real major problems with it.
The boiler is insured and there has been about 6 engineers out trying to fix the boiler but the same problem happens. The expansion vessel has been replaced a few times as they said the first one was faulty.
The latest diagnosis is that I need an external expansion vessel as the boiler cant cope with the amount of water in the system (system has been the same for 8 years and no problems). The short term fix was to use one of my radiators as a temp vessel and this would stop the overflow from the boiler. This has not happened because as soon as the engineers went the boiler started to overflow.
I'm sorry if this does not make sense but this is the only way I can explain it.
I have 3 x 600 by 1200 rads downstairs along with a small radiator in kitchen. 3 x 600 by 1200 rads upstairs and a very small rad on landing along with a towel radiator in bathroom.
I would be grateful if someone could give me any advice on this problem.
