Vokera Maxin 24e - no hot water
10 Apr 2005
I have a Vokera Maxin 24e combi boiler. Not sure of its age as it was fitted before we moved here 18 months ago. A guess would be 3-5 years. It's been fine until this morning - no hot water but the central heating still works.
The pressure gauge was pointing at 0 so i've turned the filling loop tap top increase the pressure to 1 and a half, as suggested at: //www.diynot.com/forums/viewtopic.php?t=20406&highlight=vokera+pressure
This has not solved the problem although the pressure has not dropped back down . I turned the filling loop tap 4 hours ago.
Any suggestions as to what I should look at next? There is a sticker on the front of the boiler that says to check that the boiler is fully topped up and that the domestic hot water flow rate is set correctly. I don't know how to do either of these things but don't know if i should be pottering about with the thing.
From reading posts on here suspect the problem could lie with the diverter valve or diaphram.
Thanks.
