I have got a gap of 440 mm with out the bottom bit that goes on . Do you think this will be ok as i need this height as i dont want to drill through the wall if i make them higher ???
if you are happy with it go for it, it is only a matter of preference that determines your height or if you have any tall units that you have to work to. only min height requirements when above hob space.Some people have them this low to allow short people good access
