The all important question is whether it is a vinyl paper?
If so, you will have difficulty getting anything to adhere well to it, but if it's a standard wallpaper, it is possible to hang directly on top of it. I've stripped houses with as many as seven layers of paper in the past, but I would still always recommend going back to a bare surface to avoid any possible issues.
hi it not vinyl paper, so it would be ok but best going back to bare wall, ok, i was trying to cut corners really, stripping walls worse job in the world ! anyway thanks for your help much obliged
