Washing Machine in WC
26 Jun 2010
Hertfordshire
Hello
I am planning to install a washing machine in a downstairs toilet. Room just has WC & basin, no shower or bath.
Washing machine will be around 500mm from basin.
Was planning to have an unswitched socket behind the machine supplied by a fused spur outside the room. Does this need to be built into a cupboard?
Ive seen lots of posts about washing machines in bathrooms but can't find anything about WCs
No specific rules regarding toilets, just the generic "equipment must be suitable for it's environment" stuff. Avoid putting electrical stuff too close to the wasbasin, especially if you have one of those tiny ones that likes to spray water everywhere when the tap is turned on full.
Personally i'd try to keep the FCU inside the room if possible, less confusing that way.
Is there a specific reason you are introducing a fused spur into the circuit - if the socket from which you are planning to spur from doesn't already
have a spur then there is no need to add a potential fault point into the extended circuit. Your washing machine/cable is already protected by its own
13Amp fuse.
It wasn't to add another fuse. I just thought that you were supposed to be able to switch it off without pulling the wash mach out, much like you would for a dishwasher in a kitchen.
Is there a specific reason you are introducing a fused spur into the circuit - if the socket from which you are planning to spur from doesn't already have a spur then there is no need to add a potential fault point into the extended circuit.
Indeed - and, come to that, exactly the same would be true even if the socking from which the OP was planning to spur did already 'have a spur' (originating from it) (although you'd probably then get some people arguing about two spurs with a common origin!). If the socket from which the OP planned to take his spur was itself 'already a spur' then, of course, neither a fused or unfused spur from it would be permissible.
Kind Regards, John
Contrary to what many seem to think, there is no such requirement in the regulations - and, even if there were (or if you would feel more comfortable with such a switch), then just a switch, rather than an FCU, would be adequate. As riveralt has said, introducing another fuse (in addition to the one in the plug) would, in itself, achieve nothing.
Kind Regards, John
It will be just a spur off the ring so looks like a simple switched socket will do the job.
Thanks for the advice.
That's fine, provided you take the spur from a socket which is actually part of the ring (are you certain that it is?). As I said, if the 'source socket' were itself on a spur, you would not be allowed to take a further spur from it.
Kind Regards, John
