I'm trying to plumb in a washing machine however because of the kitchen layout we have I am restricted for space.
The installation instructions for the washing machine indicate that the flexible hose (part of the washing machine) should not be extended and must be min 600mm above foor level.
The washing machine hose will reach a space where I can fit an 32mm upstand(?) and 32mm trap and from the trap run (about 1 metre of) 40mm waste pipe to connect to the existing 110mm soil pipe.
Searching through the forums I can see that 40mm is the recommended size for a washing machine waste but given the hose is only about 25mm diameter will 32mm be too small?
Fraser
Fraser
