Water dripping behind gutter
9 Jun 2014
Yorkshire
I have just done my first fibre glass roof on our kitchen.
I used roof lat to button out the edge of the roof to provide a lip so the water will drain into the gutter properly.
Well it is just a touch short and so water now runs down the facia as well as going into the gutter.
I cannot change the roof design so are there any products i could use to channel the water into the gutter. I was thinking about some triangular beading tacked onto the facia under the fibre glass protruding bit. The water would hit this and then be deflected forward more and into the gutter.
Any ideas ?
ok thanks for the idea. will look into it. But i do prefer the idea of of some type of beading painted white which will blend in with the facia a bit better.
Ok well another option you maybe able to use is a 50mm white flexible angle which comes in 5m lengths.
I ended up buying a special drip trim for the rubber roofs sold at my local plc supplier. It is a 2 part system, but i just used the angled deflector. Worked a treat and it looking in keeping with the black gutter. £15 for a 2.5m run though.
I need some more trim for the garage section, but leakage here is not as important. I may look at the 50mm angle you mentioned as there isn't room here to fit the trim i have used due to the gutter being much higher up to the top of the facia.
