water pressure very low
19 Aug 2009
If I put a small pump say 2 bar pressure pump on the hot water output and then connected the cold supply to mains.Is this a practical solution to try to inprove water pressure cheaply.
if your supplys are tank fed, then obviously it will be better.just be warned, as i mention to customers going to a pressurised from gravity system.it could cause problems with old pipework.best to check pipework first.
you can`t pump mains water
think the op was thinking of pumping the hot water.then converting the cold feeds from a tank with mains water.i hope.
which bit,hot prob no. but could still convert tank fed cold feeds to mains water feeds.
Looks ok to me.
Pump on the hot and changed the tank cold water to the outlets to mains fed.
and at the mixer you project class 2 water into a class 1 main
And the water regs say.
Backflow prevention should be supplied at all points of use, where a cross contamination is possible.
