what power saw?
Discussion in 'Tools and Materials' started by svouts, 9 Mar 2012.
  1. svouts
    16 May 2011
    172
    Thanks Received:
    2
    Country:
    Hi, I want to cut a bamboo garden screening along its length. It is 2 meters high by 4 meters long and I would like to cut it in two pieces of 1 meter high.
    Shall I use an angle grinder with a wood blade, a jigsaw or a circular saw?
  2. merlin50
    10 Jul 2010
    1,750
    Thanks Received:
    127
    Cornwall
    Country:
    someone use an angle grinder with a wood blade on this forum and they ended up dead
  3. StephenW
    9 Jul 2009
    272
    Thanks Received:
    40
    Buckinghamshire
    Country:
    What is the current situation? Is the screening currently installed? Is it fixed to a fence/trellis? Can it be removed?
    If it is loose you could roll it up and then saw it with a normal panel saw. If it's fitted I would use a circular saw or maybe a jigsaw, depending on how much control I could maintain on the power tool and the depth behind the screening and preferably using a second pair of hands. Definitely NOT the angle grinder!
  4. catlad
    29 Jul 2011
    2,725
    Thanks Received:
    364
    Lancashire
    Country:
    Roll it up tight and tie it, then cut it with fine tooth hand saw.
  5. svouts
    16 May 2011
    172
    Thanks Received:
    2
    Country:
    it is not installed yet, I will roll it up and use a fine saw
    many thanks!!
  6. big-all
    12 Jul 2004
    15,891
    Thanks Received:
    1,096
    Surrey
    Country:
    square up the ends so all tubes are level
    roll a sheet off news paper around a couple off times at the point you want to cut then you will have a strait cut all the way round if you cut 2mm away from the paper
  7. Norcon
    17 May 2008
    8,419
    Thanks Received:
    357
    Country:
    You can get a wood blade for an angle grinder.It only has four teeth. I've got a 9" one. and was using it yesterday in fact. Great for demolition work,
    Doesn't make the tidiest of cuts though.
  8. joe-90
    28 Oct 2005
    31,290
    Thanks Received:
    1,059
    Country:
    Ooer! Listen to Errol Flynn of the forum. Bragging again. :rolleyes:
Loading...
Share This Page
