i am looking to upgrade my 6 ml armoured cable for heavier duty to my new pond filter house, i need to run a cable about 45 meters to reach its destination, i have to run the following
1 x 9kw heater
1 x 8kw heater
3 x 130 watt pumps
2 x 55watt UV lights
4 x 20 watt air pumps
1 X 500 watt spot light
2 x 150 watt low wattage lighting transformers with lights
sockets for drills etc
i later want to add to this feed another summer house next door with hot tub, lights fittings etc.
i allready have a hundred amp circuit with all equip ready wired onto breakers but have had to limit what is running at any one time as its only 6mil supply,
This is currently running from a mains splitter box into the main building, running to a seperate meter in the garage next to the filter house,
this will need to be run direct from the 6 way supply splitter as this electric is to be charged seperatly from the main building electric
regards dave
1 x 9kw heater
1 x 8kw heater
3 x 130 watt pumps
regards dave
