whats the difference between...
Discussion in 'Plumbing and Central Heating' started by Dave2010, 1 Apr 2012.
  1. Dave2010
    29 Oct 2009
    167
    Thanks Received:
    4
    Country:
    I know what 3 way/diverter/mid-position valves are with the motorised heads on but I am wondering about the diverter valves that contain a diaphragm and what the obvious differences are as to their use? (apart from looks)
    I have read about how they work and understand this but what, when, where and why etc
    Do systems use both?
    Are 3 way only used if you have a hot water tank?
    Any advice would be great :)
    thanks as always.
  2. Boilerman2
    10 Jun 2009
    5,229
    Thanks Received:
    1,010
    Suffolk
    Country:
    A Diaphragm operated Diverter valve is commonly found on older Combi boilers, opening a hot tap causes a pressure drop across the diaphragm which results in the diverter valve shunting to the hot water port
    A 3 port Mid position valve is an entirely diffrent unit, it is designed to be electrically controlled, and supply heat to either heating radiators or a hot water cylinder , or both.
    Sometimes you will find an electrically operated Diverter valve on newer design Combi's A Diverter valve can only heat hot water or Heating one at a time, a Mid position valve can do as mentioned AND Both simultainously if required ;)
    • Thanks Thanks x 2
  3. onlyfitidealboilers
    11 Jan 2010
    2,022
    Thanks Received:
    151
    Aberdeen
    Country:
    You doing a plumbing course lol
  4. Dave2010
    29 Oct 2009
    167
    Thanks Received:
    4
    Country:
    no mate. Was just a passing comment from a friend who had his replaced And to be honest I was not even aware of them :confused:
Loading...
Share This Page
