Where am i going wrong
16 Oct 2006
Lancashire
Hi,Have got into building my own rocket motor and need to make e-matches as i need to set the igniter deep inside the motor, i have tried two 9v batteries in parallel, 30ft of speaker wire, one strand i would say is copper, the other maybe chromed/nickel plated wire ?
At the business end, 60 awg nichrome wire, sat on a match head, dipped in cellulose, then dipped in magnesium powder. When i try to ignite a match, at the most i bet the tiniest whisp of smoke but no ignition, when i put the e match to the battery with only 3 inch of wire, it lights immediately, is the copper wire i'm using too high a resistance? Apart from using a car battery, what else do i do ?, thanks......
I used to use torch bulbs with the glass removed...
Yes I think you need to make the resistance of the fusing wire a lot more than the feed wire so that the whole battery voltage ends up across the fuse. So thinner wire for the fuse.
To be fair, now I think about it, I also used a relay (plus a torch battery), local to the fuse, made out of a Woolworths door bell, rewired to just close and not cycle. But that is not really needed if you get the resistances right.
Maybe this would be considered as spoiling the fun, but you could use ready made igniters.....
http://www.lemaitreltd.com/p/Igniters/FeXOqTlaanI
Ideally fired from a capacitor discharge firing system to help get around the cable resistance problem...
Edit to add: These units also have a current limited test facility, allowing you to check your cable and connections without the risk of firing the charge.
http://www.lemaitreltd.com/p/6-Way-and-2-Way-Controllers/khe2btGMrgk
These items are readily available from theatrical suppliers such as AC Entertainment http://www.ac-et.com/ , 10 Out Of 10 Productions http://www.10outof10.co.uk/acatalog/Le_Maitre.html , Stage Electrics http://www.stage-electrics.co.uk/shop/sales/effects-and-effect-machines/pyrotechnics , Or White Light http://shopwl.com/ .
No license is needed to buy these items, they are available to anyone over 18.
Probably. If you have a multimeter you can measure it.
Try with your two 9V batteries in series.
A car battery won't help, but more 9V batteries might.
the long wires each read 3.1, the short 3 inch x2 pieces + 1 inch n/c wire all in one piece reads 2.7....too close?
So I think you're saying that the total resistance when using the long wires is 3.1 + 2.7 + 3.1.
If 9V is sufficient when it's just 2.7, then trippling the voltage to 27V (or a bit more) should overcome the extra resistance.
