Where can I find this? How is it called?
18 Sep 2009
London
Hello!
I am trying to assemble something like this:
This is **not** a working pipe/valve, but purely used, say, as a coathanger or a lamp base.
I guess (?) the "T" part is something like a 3/4" X 1/2" X 3/4" BSP Unequal Tee-Galvanised fitting, which I can find.
However, what could that brass "handle" be? Can I find/buy such part? How would you call it? I was trying to google for something like BSP male brass drain/cock/stop/valve but without much success.
Again, it doesn't need to have a function, but it needs to fit in the 1/2'' BSP female thread of the Tee.
Any idea?
Thanks in advance!
diodorus
It is called a crutch-head and looks like it is from a brass stop-cock, unscrewed from the stopcock body.
http://www.screwfix.com/p/pegler-stop-tap-15mm/15440
There's no reason why the thread should be 1/2" BSP, it is not made with the intention of connecting it to another fitting. It could be any random thread; you'd have to get a stop-cock and take it apart.
Yes, that was my "fear"... I was looking for something that would definitely fit.
In any case, would it be a matter of simply unscrewing the head, or would I need some tools to do that? (I'm not a plumber, obviously...)
It is a crutch-head headwork from a bibtap or stopcock, probably BS1010, probably (well, almost certainly) not a BSP thread.
Good luck!
