i have whirlpool generation 2000+ every time i put oven on it trips the electricity in the house no problem if i use the grill removed bulb but still happens any help out there sunday roast depending on answer
undone it all took out lead at back of element turned back on nothing blew so reattached element blew again but the thing is the element is working but i noticed the fan is not spining round is it blowing because fan has packed over heating inside
Does the fan share a common neutral or supply with the element (some do)
Check the resistance of the element usually around 27 ish ohms,
Is the motor shorted out or are the bearings jammed.
