wickes combi 90 fails to light and no pilot light visible.
2 Mar 2015
Leicestershire
Hello all,
I have a wickes combi 90 boiler which has a halstead 500585 board in it.
It was working then the following day decided not to, under further inspection and a friend who is an experienced plumber, he offered the suggestion that i was to change the board as the ignition side had failed.
I have since changed the board and fired up the boiler. the power light is and pressure is sitting at 1.2 bar.
The pilot light is still out but the pump and everything else seems to be running. does anyone have another direction in which i could go for fixing this problem.
All suggestions gratefully recieved.
