- Joined
- 9 Jun 2013
- Messages
- 51
- Reaction score
- 0
- Country
Hi guys
I have removed two old radiators and looking to replace them. A plumber will be installing them I am just buying the ones to be installed.
I have measured my old radiators and they were:
600mm x 1040mm the width from the pipe ends on the radiator was 1075mm
600mm x 1490mm the width from the pipe ends on the radiator was 1515mm
I am looking to replace these with the following two and am not sure if they will fit the current pipes:
http://www.bestheating.com/milano-a...ner-radiator-635mm-x-1000mm-double-panel.html
http://www.bestheating.com/milano-a...-designer-double-radiator-635mm-x-1411mm.html
The above say "Pipe Centres 1100mm (approx)" and "Pipe Centres 1510mm (approx)" is this what I need to compare to the 1075mm and 1515mm that I measured?
Thanks.
Thanks.
