Hi all
I have a single 1 way light switch fed from the ceiling via chased metal conduit (presumably original to the house 1950s). I want to add a second 1 way switch (for a new light) to make the switch 2 gang.
The conduit is on the narrow side and I wonder if I'll have difficulty feeding two T&Es down to the switch. Is there any reason why I can't use a single 3-core cable, using one core as the permanent live for both switches (split via terminal block behind the switch), and the other two as the switched lives for each switch? (all sleeved appropriately)
I await an obvious reason why this wouldn't work!
Thanks,
Thanks,
