I have changed the configuration of the contacts that I want to use across 3 sets of bifolders (these doors have been by far the biggest headache, thought I had a solution thanks to scott1980 with the Texecom Duel contact and viper but they turned out to be too larger footprint and fouled the reveal ).
Any way back on subject - I had successfully set it up an set it up on the bench using 3 magnetic contacts with 1 contact at EOL using a 2 K and a 4K resistor and the other 2 contacts with 2 K only. Unfortunately although the circuit worked well the size fit of the contacts into the doors didn’t.
So….I now have 3 SC513/WH/G3/B contacts that fit in the frame recesses the doors perfectly, cable exits ideal etc, they operate individually as they should when tested at 7K open and 2K closed but I struggling with how to wire them in series onto 1 zone. Can it be done? if not any suggestion for suitable replacements. I can fit 15mm x 15mm max.
