Wiring for fluorescent lights in the loft?
15 Sep 2010
Surrey
Hi all
Im just about to fit 2 1500mm fluorescent lights in the loft, im sure im competent enough as im an auto electrician by trade :confused:
I have fitted the lights where I need them and have now started thinking about the wiring! Im sure I have it right in my head and have done the following diagram
Can someone please confirm if this is the right or wrong way to do this???
Cheers
Yep thats fine, except you will end up with a brown wire (rather than blue-sleeved-brown) in both the common and L1 (unless you have twin blue . .)
Loads more lighting in the wiki
What does the existing sw control? if you want you can change to a 2-gang and have them on their own switch.
The switch in the pic isnt mine, its one i got off the.net for ease of use for the diagram :) although the rose is mine
In that case, as Skenk says, go right ahead and yes you will have two brown at the switch.
Thanks for your imput guys, its all done & working:cool:
I missed the wiki (would have saved me doing my own diagram) :oops: but theres some useful info & tips in there :)
