Wiring up a new ceiling light
10 Dec 2009
Middlesex
I'd like to install a new light fitting in the front room but have a few questions regarding the wiring.
The instructions that come with the fitting say that any existing ceiling rose is to be removed and that the wires should go directly into the block provided with the new fitting.
Now I've taken off the ceiling rose cover and have identified the switched live.
There are also three looped wires and 3 neutrals connected up to the ceiling rose along with three earths. See attached image
View media item 75256
The terminal block provided is only a 4 way block which leads me to my main question...is the block provided too small for me to safely fit all the wires back in after removing the ceiling rose?
According to the instructions any looped wired go into the additional 4th terminal provided.
That wounds mean one terminal for the switched live, one for all the neutrals, one for the earths and the additional fourth one for the looped live (red) wires.
I'm not sure this is correct and think I may need a larger block.
Can anyone advise?
It doesn't sound like u have any more wires than usual so should fit.
Just make sure u mark the black switched live.
yes the number of wires is fine. i just wasnt sure about wiring several wires into a single terminal.
it hanks for the replies + have had a read of the wiki page also and it makes sense.
Thanks again.
Rob
