All combi boilers can supply a mixer shower, provided the mains cold supply is of adequate size to supply all your hot and cold requirements. The pressure per se is rarely a problem, but the flow rate is often inadequate. This has been dealt with many times and if you search you should find recent threads.
As far as the not water is concerned, the combi will happily supply one shower if no other hot outlets are in use. However when other hot taps are opened, there is competition for the limited supply of hot water which will tend to be won by the lowest outlets and/or those nearest the boiler.
24kw output boiler will deliver around 9 litres/min flow. Better to go for a 28kW or even 35kW for proportionately better hot water flow rates.
