Hello,
I've taken some time to read through the forum and have an idea what the problem with the boiler is. But I'd like to just make sure, if you guys don't mind.
I have moved into a place with a Worcester Bosch 280 RSF combi boiler that has problems keep the hot water temperature the same.
I let the hot run for a minute or so and the pilot light goes out, meaning the waters get colder. After 20-30 seconds the light comes back on and the water gets much hotter, like its supposed to be.
I measured the flow of the water (i had a bucket, no idea on the amount the bucket holds) and it took 24 seconds to fill it with cold as opposed to 57 with hot water. I understand, again from reading this forum, the difference is far too marked.
All of this leads me to conclude that the heater is full of something stopping the water/heating.
Would this be the correct assumption and would you guys recommend getting a new one fitted or cleaning out the old one? I need to know what to ask for when I speak to an engineer.
Thanks.
Thanks.
