Worktop is 635mm but Jig doesn't have this slot... What to do?
27 Sep 2011
I have an Ikea Worktop which has a depth of 635mm
However the jig that I have only has slots for worktops with a depth of 600, 615, 650 or 700mm
In this situation, what do you do?
I am a novice so could you please explain how you 'tack on a strip' to the worktop?
What sort of worktop is it. Wood or laminate, square edge or post formed.
Check this link out, and it should explain things quite well. As you can see from the picture showing Left hand female joint (and as Foxhole mentioned) you just need a 15mm block at the back with the pin set to 650, to get you to 635.
http://www.raygirling.com/wtjig.htm
@Doggit thanks for the link.. however guys I have another issue... Sorry to be a pain!
It turns out the old worktop has a depth of approximately 585-590mm.. so if i use the new piece i.e. 635mm i believe that it will leave too large an overhang
So I plan to use the plunge saw to get it down to 590mm..
Using Foxhole's logic, shall I just tack on a strip of 10mm timber and use the 600mm marking?
I'd say that 590 is on the short side, especially as most worktops are 600, and that's what I'd suggest you aim for; how much overhang do you currently have. Have you got a sink going in this piece that would benefit from a longer overhang; do you have any washing machines etc, that would also benefit.
@Doggit You are right, when you say that I should aim for 600..
Currently. the overhang is 16mm (from the base unit)
However having done some googling this appears to be very short as the typical overhang is approx 30-50mm
Therefore the 600mm worktop, would leave me with with an overhang within the normal range
So I plan to cut the 635mm to 600.. Then use the jig at that setting
Thanks for your help.. you've been brilliant!
Either cut to 600mm or move the cup'd to use the full 635 depth.
What's a cup'd?
and is there a place that has a glossary of all kitchen fitting related terms?
What sort of plunge saw do you have veedee, one on track by any chance, or are you referring to a circular saw. With a good quality track type plunge saw, you can cut from the top of the worktop, but with a circular saw, you cut from the underside.
Foxhole I knew that I shouldn't have asked lol.. Total cringe
Conversely, Doggit I am glad that you asked that question.... I have the Makita SP6000J.. It is a fantastic piece of kit!
It cut through the worktops, like a hot knife through butter :D
Comes with a 2x 1.4m track.. Well worth every penny..
Apologies if I come across like some sort of sales guy.. but I am truly amazed at the job this plunge saw is able to do
Makita SP6000J
