Worktop joins
22 Feb 2015
Kent
I'm fitting a worktop but the mitred angle does not fit exactly right I have done everything I'm told and I can't work out why it has gone wrong can anyone help.
A common mistake is to assume the corner is an exact 90 deg.
You must lay one worktop over the other to get the real overlap angle
The other possibility is if you didn't use a jig your guide was not at the exact measurement
