wrought iron gates
3 Apr 2010
Dorset
Hi, I have 2 small wrought iron gates, 1 at each side of my front garden. The postie and "flier delivery ppl" come in one gate and go out the other - leaving both open!. I looking for some way to make them "self close". Both of the gates are set between brick pillars, so I can not use a spring jobbie - the kind that is used on wooden gates. Help pls.
Hi, I can not come up with a way to secure/fasten the spring to the gate.( the fixing plate at the end of the spring is wider than the gate frame). I dont really like the idea of drilling the brick-work to secure the other end either. I would think that the stress/pressure required by the spring to close the gate would not take long to crumble the bricks where the screws secure that end of the spring.
How are the hinges fixed to the brickwork? If it's just screws it should be possible to move the bottom hinge so that the gate will close under it's own weight.
Altenatively, and I have seen this done, a little Heath Robinson but a cord pulleys and weights could be rigged up.
Hi, the hinges are sunk in to the brick pillar. Only have the pivot points sticking out, that the "gate eyes" (at the back of the gate) slot over. I had thought about a pulley sytem but it seems rather elaborate. I've been trying to think of some way that the gate will lift slightly as it opens, then the natural weight of the gate would cause it to close. (I hope that I am making sense here).
