Hi All
Finally got round to fitting the alarm. Little problem though - forgot to turn on the CU internal battery before wall mounting it. Obviously this needs to be on in case of mains failure, so can I unclip the CU from the mounting plate withoutthe siren going off? (even when alarm is OFF)If so, what is the best way? should I disable the siren Also, is the entry delay dependant on the battery being activated as the alarm is instantaneous even on a sensor designated as entry. Also, chime doesn't work. Can it all be related?
Thanks, Kev
Thanks, Kev
