I have a quantity of salvaged oak blocks, 500mm x 70mm x 19mm. They have a groove about 3mm wide and about 10mm deep running around all 4 edges. They were previously mounted with bitumen, but the bitumen was planed off before I got them.
I want to lay them in a herringbone pattern in a second floor bedroom 3m x 4m. The base is a concrete screed (put down 20 years ago), It seems to be about an inch thick over some sort of wood subfloor, the whole lot supported by 100 year old oak trusses.
I am a competent DIYer, but want some advice because this application seems a bit different to the dozens of others I have read about on these pages.
Is the groove in these blocks intended for some sort of biscuit or jointing strip? If so, what should I use?
From previous advice here-abouts, I like the sound of Elastilon, is it the right product for this application?
If not, what technique is best? The room will be subject to a fair range of humidity through the year, I am a bit nervous of gluing down, as I have recent experience of a (professionally installed - or so I thought) oak floor which tends to cup in summer.
If I go with a floating floor, I imagine that the blocks need to be interlocked?
