So replaced the two old ugly X10 appliance light switches in my bedroom and installed a new Fibaro FGS-222 Z-Wave enabled relay module inside a 47mm dry-line back box along with a standard double switch for local control.
Pain in the *** to get it all in the back box and get the switch screwed on, but after a bit of fiddling and rearranging of the wires I manage it. Screws on relay module are also stupidly tiny and don't look like they will hold up for the job. (sure they will.
Being that I had cables for Feed In, Feed Out, Light 1, Light 2, I should of joined the feeds up outside the dry-line back box using a MFJB and had just a single feed into the dry-line back box - but managed to get it all in in the end as said.
Before screwing switch on:
View media item 98052
Anyway, screw the switch on, and re-energise the circuit. 6A Type B MCB immediately trips as I also hear a pop from my bedroom. RCD is unaffected.
I Immediate re-energise the MCB for a second time, this time everything appears normal; however I de-energise the circuit once again and check inside the switch to make sure everything is ok.
Below is what I got:
View media item 98053
Despite only tripping the MCB and not the RCD initially, and the black skid marks inside the back box; the module is fully functional and does not smell like burnt electronics at all.
Don't know where the short came from for sure, but there was one wire going to the switch from the module what looked slightly charged, so I of course replaced that and inspected around the charred area.
Maybe there was a short to the front of the earthed switch and the MCB tripped before the RCD could, and cleared the fault in the process.
Regards: Elliott
Regards: Elliott
